New member Username: Tw33k2514Post Number: 1 Registered: Jul-06 | ok im going to be buying a new HT receiver in a week or so and i am not exactly sure wich one is going to be the better one. I have a budget of $550 max Speakers I Have: Infinity Primus 360's Infinity Primus Center/4 surround Infinity PS-10 10 inch Powered Sub Receivers In Question: [URL="http://www.harmankardon.com/product_detail.aspx?Region=USA&Country=US&Language=E NG&cat=REC&prod=AVR%20340&sType=C"]Harman Kardon AVR 340[/URL] [URL="http://www.onkyousa.com/model.cfm?m=TX-SR703&class=Receiver&p=i"]Onkyo TX-SR703[/URL] basicly those are the ones i think look good, if you have one not on that list in my budget then go for it. any help is awesome. thanks |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4291 Registered: Mar-05 | For $550 shipped you can get the HK 635 from 6ave.com (list $1300) ... your 360s will appreciate the extra power. |
