Posted on Any comments on these speakers is much appreciated? Pros and cons of each, is it worth spending extra money on 604. Will most likely pair with NAD amp. 352 or 372. Would this be a good match ?? Thanks in advance. |
New member Username: Eld
Post Number: 7 Registered: Dec-05
Posted on SamK, Are you planning to match the speakers with a sub? If you are going with a sub, I would recommend getting the 603 or if you don't mind bookself, checkout the 602s3. I think they sound just as good. Without a sub, I would spend the extra money and get the 604. The 604 lows are pretty impressive, and you wouldn't miss the sub for most applications. |
Bronze Member Username: 514329
Post Number: 61 Registered: Jun-04
Posted on the 603 are still boomy than the 604 in my oppinion. do an A/B on it if you can cause I did. |
