John McA Unregistered guest | Does anyone have recommendations for reasonably priced outdoor speakers? Has anyone ever used any of the wireless speakers and do they work well? |
Silver Member Username: EdisonGlendale, CA US Post Number: 794 Registered: Dec-03 | Outdoor speakers will sound better - Niles audio sounds good - ebay sometimes carries them, |
Silver Member Username: EdisonGlendale, CA US Post Number: 795 Registered: Dec-03 | Check hear for Niles outdoor speaker - Os-6 is pretty good model for $200. http://www.hifitrader.com/dbprogram6.php?searchquery=Niles |
John McA Unregistered guest | I figured wired speakers would perform better, but I am dreading the wiring. My stereo system is on the opposite side of the house from the deck. |
Silver Member Username: Touche6784USA Post Number: 496 Registered: Nov-04 | you could always get a new reciever, duh. |
John McA Unregistered guest | Out of the budget, Chris and I also have a 400 cd player attached -- can't duplicate that. |
Silver Member Username: Joe_cOakwood, Ga Post Number: 687 Registered: Mar-05 | mirage oasis II outdoors for 100-200 pr depending on where you get them. |
Silver Member Username: EdisonGlendale, CA US Post Number: 812 Registered: Dec-03 | How long is the wire going to be? Make sure it's thick enough - the longer the thicker it has to be. |
Anonymous | Yeah, no 24 gauge this time. |
Anoni Unregistered guest | Christopher is nothing but a little s h i t less kid whose face is probably still full of pimples .....Grow up! |
John McA Unregistered guest | James, I figure the wire will need to be about 100 feet so I will do minimum 16 gauge and probably 14 gauge. I can get at the wall behind the stereo fairly easily and it will run right through the crawlspace. I am just not real sure about getting through the wall on the other side by the deck. Wireless sure sounds easier! |
