Anonymous | I noticed on my new home theater that when changing menus on the dvd player that there is a very low audio pop in my speakers. It doesn't do this unless I change something on the dvd menu. What is this? Is this normal? It is like right before the audio comes on on the dvd menu, you can hear the same audio for a split second and then it starts on the dvd audio. Thanks in advance... |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 4405 Registered: May-04 | In the audio industry the phenomenon you are experiencing is commonly referred to as "cheap-@ss switching". |
Anonymous | Is this a receiver problem or a problem with my dvd player? |
