Like
Pre-amp from amp
Username: Dewey
Hi--I have an old Technics stereo integrated amp. The amp itself has blown, but the pre-amp section still works fine. I'd like to remove and keep the pre-amp, but I'm not sure what equipment is vital and what is not. Can anybody offer any ideas?
Thanks
Dewey
Username: Jan_b_vigne
Dallas, TX
Post Number: 4024
What do you mean "remove and keep the pre amp"?
Username: Dewey
Let me try and explain this better. I have a Magnavox console stereo. The changer has a magnetic cartridge, but the amp is rated for a ceramic. I'm using the old Technics amp as an external pre-amp, but as is, the Technics amp is too big to mount inside the console. So I'd like to remove just the necessary componets from the Technics amp, instead of using the entire thing, and mount those in the console. Is this possible?
Dallas, TX
Post Number: 4026
Not really. The way most integrated amps are constructed there is no easy way to separate the two sections. The pre amp still depends on the power supply which takes up quite a bit of the space in an integrated so you would more than likely end up with pretty much the same sized box to mount the pre amp into. You can look around for a separate pre amp and use it. The used market has pre amps as good as your Technics for $50 and up. That would make more sense than trying to separate the two sections of what you now own.
Username: Dewey
Thanks Jan, I appreciate it.
Username: Edison
Glendale, CA US
Post Number: 625
They don't have very good sound anyway - take this opportunity to get something that really sounds good - like onkyo TX-LR552 for instance - only $200 on the web. Sounds smooth like an upscale piece - it will be a big improvement for not much money.
Facebook
Directory
