Bronze Member Username: TriniPort of spainTrinidad Post Number: 16 Registered: May-05 | specs 2300@1 ohm model Q1 3000d any recommendations |
Silver Member Username: EdisonGlendale, CA US Post Number: 629 Registered: Dec-03 | In car amps, I like Nakamichi, and mcintosh. They are big names in hifi - the Kole is not so known, so I would shy away from them. If you are bent on getting them, I would go with a class D amp they have. If you don't want to pay that much for the above 2 ones, look into eclipse amps. if you don't mind used, get them at ebay and end up with better quailty for the same money. |
