Need Help
Username: Weenienerd
Okay, I have this old Sony FM Stereo/FM-AM Reciever STR-AV210 reciver I use them to power a pair of old jensen speakers.
It was working fine until now Only one speaker will work the other one won't. I know it's not the speakers that are the problem because when i switch them the other speaker still works.
This is the same for A and B only both Right speaker output seems to work but not the left sides.
I hope this is something easy to fix. I don't want to buy a new one since it's just used to listen to music.
Username: Dmwiley
Post Number: 746
Unless the unit has user replaceable fuses, cost of repair would likely exceed value. Probably time for replacement.
Mr. Nerd
Looks like I'll need to replace it.
I took a look around and there's two recievers that fit my price range. Which one would be better to get? even though I know these are not the best kinds
Insignia IS-HC04091
or
Sony STRDE197
Thanks
