I have a rx 540 and i was wondering whats the best matching speakers for it. I was scannin wats around and i have narrow it down to couple of floor standing and few bookselves based on my budget/.
It would be really helpful if ne one can give suggestions other than changing my amp(cause i dont hav ethe money right now).pls let me know ne other names u feel are good with yamha rx 540 thx a lot
On your list the best match with Yamaha is the PSB. I would suggest you look at Paradigm. Nothing matches better with Yamaha. The Mini-Monitor would be a very good choice and fit's your budget. If you can swing $500 or so also check out the Paradigm Monitor 5.
