Kickers
Username: Liljohn88
Post Number: 13
does anybody know how to put 2 subs together on a mono amp without blowing them and how do you determine how much power will be going to each sub
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 99
what subs an wat amp an what voice coil ohms
Username: Liljohn88
Post Number: 14
i have 2 kicker comp (250 rms) 500 max and i was thinking about buying a mono amp but dont know what kind i need
Username: Goose5714
Post Number: 331
you need to give us a link/or model number of those subs or tell us the voice coil configuration. The vc config will determine the amp you need, and yes you can use a mono amp and will probably want to you just have to present it with the right ohm load...which is why the voice coil config is important
Username: Liljohn88
Post Number: 15
http://www.cardomain.com/shop/item.pl?sku=KIC01C154
theres the link for them on cardomain but do you guys think i should just buy a 2 channel amp or a mono which one will hit harder without bustin up the coils
Username: Rovin
Trinidad & T...
Post Number: 6343
buy 1 of these 500/1 amps
https://www.ecoustics.com/electronics/forum/car-audio/206194.html
Username: Liljohn88
Post Number: 16
i would but im on a 200-300 budget
Username: Liljohn88
Post Number: 17
Username: Killer44
Ontario Canada
Post Number: 425
GET AN AMP THATS 500RMS @ 2OHMS...
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2373
so you have two SVC 4ohm subs...right?
250wrms each.
look at these amps:
jbl bp600.1
orion XTR500
memphis 16-mcd500
kicker kx500.2
rockford 500S
rockford P6002
hifonics BX605
the orion would be my first choice.
all of those can be had for less than $200.
Username: Liljohn88
Post Number: 18
aright thanks alot guys
Username: Kickerandy
Vesta, MN America
i just recently bought a kicker 10" L7 and i want to put it behind the seat of my truck, i was just wondering what would give off the most bass......ported or sealed.....or any other box desighn you would recommend???I NEED to know!!!help me out!!!!
Username: Andysd03
Post Number: 18
ported well give out a big noticeable differece of bass by at least 3 db so ported gives out more bass and sealed is more sound quality and bandpass is another good box desisng but if i were u choose ported
Username: Liljohn88
Post Number: 19
heres a picture of what i got
Post Number: 2375
andy werner,
i built a ported box for an L7 10" about 3months ago. the guy that i did it for had the sub in a sealed box before i built the ported one. when i installed the ported box...he was utterly amazed how much louder it was.
go ported...1.5-2cuft tuned 32-35hz w/ 20sq inches of port.
Vesta, MN America
Post Number: 9
is the port that your talking about a slot port or round port?????
Vesta, MN America
Post Number: 10
i kinda like the slotted port the best, so is there anyway i could make a slot port that is 20 cubic ft.??? or do i have to make it a round port????
Vesta, MN America
Post Number: 11
20 square inches port...my bad
Username: Liljohn88
Post Number: 21
i wonder if i should order a ported box for my 15's
Vesta, MN America
Post Number: 21
if i were you i would really think about making the box......its ALOT cheaper, and you can choose the color of carpet to match ur car/truck....my friend ordered one once before, and there was alot silicone missing inside to seal it up, and it sounded like shi*t, and then he had to go out and buy some silicone to fill it up, and i jsut think you should buile one.....there simple to build
Username: Liljohn88
Post Number: 22
i just dont know much about building boxes and i dont know if it would sound good or not
Vesta, MN America
Post Number: 26
oh i know it would sound good but if u dont know much about biulding boxes...then i would order one
Username: Goose5714
Post Number: 338
Have someone build one for you, better than prefab and probably cheaper, go to the caraudio.com forums register, and post in the box forum there are many good people there who build good boxes for reasonable prices...
Username: Liljohn88
Post Number: 23
im thinkin about ordering this slot ported box for my 15's what do you guys think, will it sound good?
http://cgi.ebay.com/DUAL-15-PORTED-3-4-MDF-SUB-ENCLOSURE-SUBWOOFER-BOX_W0QQitemZ 5879503476QQcategoryZ14945QQrdZ1QQcmdZViewItem
Username: Liljohn88
Post Number: 24
Username: Nissankicker
Grambling, LA USA
Post Number: 20
Instead of ordering a slot ported box for your 15... Just go to an a Car Audio Shop and ask for a SuperBass Probox for a 15" speaker... It'll have everything you need
