SX15 box
Username: Terry6405
Sullivan, IN US
Post Number: 513
i already built a box for my SX15 at 32hz but what if i made one at like 40hz?
what would be the difference?
it would be louder right?
would it just sacrafice some SQ or what?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2355
you would have a spike in SPL about 42-45hz...but you would loose your freq. below 40hz.
A box tuned to 40hz would be more of a SPL competition box. I would not recommend it for daily...but you could run it daily (just set you SSF right) By tuning that high, you are gonna have a boomy box w/ little or no low-end.
Username: Terry6405
Sullivan, IN US
Post Number: 514
yea forget that
what about like the 35-36 range
Post Number: 2359
35hz daily wouldnt be that bad...not that good either.
IMO, 30-32hz is about perfect for an SX15 daily. Just give it ~4.5-5cuft.
Username: Terry6405
Sullivan, IN US
Post Number: 520
yea i dont have room fot that big a box
i had to actually kick my box to get it in and its only 3.6 cu ft
Post Number: 2374
what vehicle is this in?
Username: Terry6405
Sullivan, IN US
Post Number: 522
89 accord
https://www.ecoustics.com/electronics/forum/car-audio/205817.html
you can see that i have some space left, but getting it in is the problem
i even had to drop the sub in after i got the box in there so it would fit
i dont know if i could fit a bigger one if i took out the trunk fllor or not but i dont think so
any ideas
Username: Terry6405
Sullivan, IN US
Post Number: 524
i just listened to some test tones on my sub and they were pretty loud but i heard a funny noise and when i got back to my sub i noticed that a part of the sub wasnt mounted flush and air is leaking out of it. i put my hand over it and it sounded perfect
so thats something i gotta do tomarro, fix the hole and mount it flush at leakless
hopefully this will improve my listening
