New member Username: Mikerod007Post Number: 3 Registered: Oct-07 | I have a Klipsch SW12 II. I also have Rti4's. I want high to go to Rti4's. I set the crossover on the sub so lows go to sub. However, what does the phase knob do(Switchable 0 or 180 degrees)? How should I set it? |
New member Username: Mikerod007Post Number: 4 Registered: Oct-07 | Here is the link to specs http://www.klipsch.com/products/discontinued/details/sw-12-ii.aspx#specification s |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11581 Registered: May-04 | . You set the phase switch to which ever position sounds best over the broadest area. Since phase is relative you will only be correct at certain frequencies and incorrect at others. Experiment and read your owner's manual. |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2640 Registered: Dec-06 | BUUUUUUUUUURP. Oh, excuse me. And no, this is not spam. I had to burp. Excuse me again for burping. |
