i have some sae a202 amps do folks like theies amps how do i run them nead a din pin out digram this was a multie amp rack and dont know how to triger amp on thanks brett
A pin out diagram is only worthwhile if the person using the amps followed the diagram. When dealing with an unknown quantity such s this, it's best to do a physical check to see where each wire is routed. Take the cover off and follow the wires to their destinations. To assume the wiring was done correctly is to be foolish.
