Like
Cambridge Audio PM01 PRE-AMP
Username: Eggenberg4ever
Edinburgh, Scotland United Kingdom
I'm adding a phono stage to my Cambridge Audio A1 mk3.
What techical expertise & equipment do I need to install a Cambridge Audio PM01 PRE-AMP stage to my amp?
Basically, what do I do?
Help! There's a heap of vinyl screaming to be played here!
joeman12
Username: Varney
BirminghamEngland, UK
Post Number: 300
If it's an external one, then you simply connect it between your turntable and amp, through the phono-input. If it's an internal upgrade your'e having, I believe your dealer will have to send it off to Cambridge Audio to have it fitted.
Whatever, talk to the dealer from whom you purchased the A1.
V
Username: Ca_convert
CardiffUK
Post Number: 85
The dealer you bought it from should be able to install it into the amp if it the latter version (so Richer sounds claimed anyway)
Facebook
Shop Related Deals
Directory
