Silver Member Username: MystrePemberville, Ohio USA Post Number: 696 Registered: Sep-05 | All right, I'm about to start on Part 3 of this project. Why? Becasue it's getting close to being warm enough to finish. Part 1: https://www.ecoustics.com/electronics/forum/car-audio/640043.html Part 2: https://www.ecoustics.com/electronics/forum/car-audio/650046.html For now, I got my stickers for the subs and ordered some others, not exactly sure where I'm gonna put them. ![]() ![]() 2 of these are going on the subs, pics later |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1956 Registered: Sep-09 | bought dam time |
Gold Member Username: Wolf_houndPhoenix, AZ Post Number: 1358 Registered: Sep-05 | lol taking almost a year to finish your project. Hopefully it turns out the way you want it. |
Gold Member Username: JbpittPittsburgh, Pa. Usa Post Number: 1133 Registered: Jul-09 | The stickers on the subs is a good idea. What all do you have to finish? |
Platinum Member Username: InsearchofbassPost Number: 16720 Registered: Jun-04 | keep this thread moving i want to see the end result |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 709 Registered: Sep-05 | Julian, thanks. Sean P, thanks and I have to put my alternator back in, run the wire from starter to alternator, fix plexiglass, run wires for new amp and put the box with subs in. sean, thanks. OK, now updates, it's been raining here so I haven't been able to do much. I did get the question mark stickers on the subs though. Here are some pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Silver Member Username: Lord_huggingtonOntario Canada Post Number: 287 Registered: Oct-10 | What is that, AQ or DC? You really gonna not tell anyone when they ask? Way to give those guys sales. |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 710 Registered: Sep-05 | Sundown. Yes, I will tell anyone that asks. I also plan on having a Sundown sticker somewhere near them when I'm done. |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1960 Registered: Sep-09 | i like it, whats with the white marks, also you forgot to call again. |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 24483 Registered: Jun-06 | Nice detail with the stickers. Make them your own lol! |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 711 Registered: Sep-05 | deathoob, Thanks, the white marks are where I drilled the holes and I know. Hopefully tomorrow. Paul, thanks! |
Gold Member Username: Wolf_houndPhoenix, AZ Post Number: 1359 Registered: Sep-05 | U know what would of looked nice? If you went with black carpet with a green port like the color of the stickers. And what happened to the rubber outing that goes on the sub? imo it would of looked much better. |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 712 Registered: Sep-05 | Thanks for the idea Julian. I wish I would have heard or thought of that before I had my box built. As far as the rubber, I have it, just forgot to put them back on for the pics. |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 751 Registered: Sep-05 | Hey all, so who's ready for some updates? First nice day with no kids and no baseball! I promise this will be done in June! Okay, so I got my new power wire, RCAs, speaker wire and in-line fuse today which all is for the 4 channel amp. Got the power wires through to the battery with high temp split loom tubing. Started to run some of the speaker wire, mounted the in-line fuses, and got all of the new RCAs hooked up to HU and partially ran through the car. Pics below and more to come. ![]() New power wire (4 guage) RCAs (4 channel) & in-line fuse holder ![]() New in-line fuse holder ![]() RCAs (all) hooked up to HU ![]() new in-line fuse holder mounted ![]() both power wires mounted ![]() new power wire ran ![]() new speaker wire ran ![]() new remote wire, RCAs and speaker wire ![]() again (better) ![]() new ground wire ![]() wiring mess in trunk |
Gold Member Username: Van_manBoston South, MA Post Number: 5465 Registered: Mar-06 | looking good. I hear you about wanting warmer weather to work. Its been a long wet winter. Im acually getting inspired to begin my next set of upgrades/replacements. I like the stickers. |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 2033 Registered: Sep-09 | finely, lol. nice start, work on your wire management you will thank your self later. well mine is not great but its nice until you hit the trunk. excited to see how this turns out. |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 754 Registered: Sep-05 | Okay updates. I haven't been able to do much. Baseball, baseball and more baseball. I have hooked up the 4 channel amp, ran all of the speaker wires and the RCAs. I also discovered that I needed to add a fourth toggle switch. Why? Becasue if I didn't the only time I would have music is when the bass was on and that wouldn't work for all of the time. So, I made a new faceplate for my toggle switch box. I used thick plexi. That is in and all hooked up. I also began working on getting the new plexi in for the amp rack. Next month I am hoping to order my new box. It will be black carpeting with a green port. Pics: ![]() New faceplate with black plastic I didn't use ![]() New faceplate plexi with black plastic ![]() New faceplate plexi ![]() New faceplate plexi with black plastic ![]() New faceplate plexi with black plastic & toggles ![]() Again ![]() New faceplate plexi glued ![]() New faceplate plexi painted ![]() New toggle box with all 4 toggles mounted ![]() Again ![]() Old plexi taken out ![]() Old plexi on new plexi |
Gold Member Username: JbpittPittsburgh, Pa. Usa Post Number: 1195 Registered: Jul-09 | Looking good man. Your not going to know what to do with yourself once this all gets put together. lol And btw... nice headunit! |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 755 Registered: Sep-05 | Thank you and that 's exactly what I'm afraid of, getting bored and wanting to spend more money. LOL Yea thanks, you like that? You still got that ED? |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 2035 Registered: Sep-09 | glad you are able to get working again, think you are close to having a ETA? |
Gold Member Username: JbpittPittsburgh, Pa. Usa Post Number: 1199 Registered: Jul-09 | Yep still got it, currently hooked up to my Q. Thats the bad thing about car audio though. It seems no matter how much time an money you put into it your job is never done. lol |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 24727 Registered: Jun-06 | Tell that to NASA, or our defense department, CIA, FBI, ect, ect, lol. You get the point. It's always a work in progress. |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 756 Registered: Sep-05 | @death: End of June hopefully. I decided that the wiring mess behind my HU needed to be cleaned up so, I started on that. Now I am going to bed. Here are some pics: ![]() Start of the clean up ![]() Some of the wiring ![]() Start of clean up again ![]() This is what my front seat looks like ![]() This is where my center console is supposed to be ![]() The back seat and 4 channel amp |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 24729 Registered: Jun-06 | That's a wire orgy right there!!! |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 2038 Registered: Sep-09 | how do you have more wire then i do? |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11890 Registered: Jul-06 | Just read your part 2 thread Nice choice of amps and battery, I approve |
Gold Member Username: JbpittPittsburgh, Pa. Usa Post Number: 1202 Registered: Jul-09 | Holy clusterphuck of wire! lol |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 757 Registered: Sep-05 | 6/09/2011 Okay, first of all, I really meant to answer/respond before this, but I went to jail for 10 days. PLEASE DO NOT ask why, it is very personal. Anyway, I have been home since monday and have been busy. First of all, I finalized the wire cleanup. I have also built a rack for my 4 channel amp. It will be leaned against the back of the sub box. Speaking of sub boxes, I am still trying to decide what to do, order or build myself. I am leaning towards building myself because of cost. I got my new HO alternator back in and I have put my high heat split wire looming on all of my big 3 and amp wires. I am also going to put "Riddle Me This" on the inside of my trunk lid with the green neon wire. Now, the pics: ![]() Wire mess cleaned up complete ![]() Again ![]() New amp rack for 4 channel amp ![]() Again ![]() Once more ![]() And with the amp on it ![]() Green lights for new amp rack ![]() Again ![]() One more ![]() With amp ![]() HO alternator back in ![]() Big 3 with protection ![]() amp wiring with protection ![]() ![]() ![]() 6/10/2011 Finished the new amp rack. Pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() So, other than the sawdust, staples to be painted and a little more paint, this is done. I'm going to bed, I'm beat! |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 2051 Registered: Sep-09 | nice, its finally coming together, i am also tempted to ask the stupid question. mostly because you said i couldn't lol. |
Gold Member Username: JbpittPittsburgh, Pa. Usa Post Number: 1209 Registered: Jul-09 | Looks good man...now lets get a vid up so we can finally hear this dam thing! lol |
Silver Member Username: MakinblakMonroe/Monticello, La/Ar Post Number: 632 Registered: Oct-10 | Congrats. I know ur stoked about it. Let's see some pics of the big pic all installed |
Gold Member Username: Van_manBoston South, MA Post Number: 5476 Registered: Mar-06 | Nice job. |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 758 Registered: Sep-05 | death, thanks and it is way too personal. Art, thank you and I promise very soon! Slackin, thank you and again, very soon! Marc, thank you! I want to clarify that this diagram is correct and will show my amp a 1 Ohm load. http://s161.photobucket.com/albums/t227/nyoc2020/?action=view¤t=subwiring. jpg |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 2054 Registered: Sep-09 | if D4 yes |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 768 Registered: Sep-05 | VIDEOS!!!!!!!!!!!!!! Yes I said VIDEOSSSSSSSSSSS! |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 2063 Registered: Sep-09 | looks good, about time. how you liking everything? |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 770 Registered: Sep-05 | AWESOME! Except for some cosmetic things. The box is covering up the plexi, the other amp rack is not fitting like I wanted. Just petty stuff that I will work out. As far as the subs, WOW! It's like riding a roller coaster, when your done, your like phew! LOL |
