New member Username: Jet2001Post Number: 6 Registered: Mar-05 | I'm looking to buy a pair of wall mounts for Polk Audio R15's. I need a mount that can hold 25lbs. I'd like to get them for under $50 if at all possible. If anyone has any links or suggestions to where I could find something like this, I'd really appreciate it. thanks JT |
Silver Member Username: Paul_ohstbucksPost Number: 415 Registered: Jan-05 | Have you even looked?? Im sure if you google 'speaker wall mount' you'll get a gaggle of possibilities. http://www.allenproducts.com/speaker_mounts.htm It took all of 5 seconds for me to find that link. You might try to 'google' for youself, and Im sure you'll find exactly what you're looking for. |
New member Username: Jet2001Post Number: 7 Registered: Mar-05 | Well, yes I have looked...but I thought that maybe someone around here knew of something better than just googling. Websites, stores, etc...googling may get you to sites with the most hits, but not necessarily the best place to get what you want. Thus my question in this forum. |
Silver Member Username: TevoChicago, IL USA Post Number: 143 Registered: Feb-05 | Try them? http://www.omnimount.com/ |
Bronze Member Username: Jim_mcbobPost Number: 47 Registered: Nov-04 | Omnis, especially the 30.0, cost way more than $50/pr. But, having used Omnis for two sets of speakers, I can say that they're worth the price. |
New member Username: Jet2001Post Number: 8 Registered: Mar-05 | Thanks Tevo and Jim-Bob...I see a few retailers in my area carry these mounts. I think I'll check them out this evening. |
Bronze Member Username: Jet2001Post Number: 26 Registered: Mar-05 | I found a pair of Onmimounts on line and ordered them. They came yesterday and I installed them last night. I must say, this was a great recommendation. They were easy to put up and easy to hang the speakers. They are sleek and sturdy and look great. Thanks again guys. Anyone will get a recommendation for omnimounts from me. |
