Gold Member Username: FrkkevinLake Worth, Texas US Post Number: 1408 Registered: Nov-05 | Just figured I'd throw out an update. The amp will be install tomorrow during the competition. If everything works properly I'll post numbers I pull with the new amp. If not I'll hook up the old amp and still post numbers. Pictures will be following in this post tomorrow night. ![]() ![]() |
Gold Member Username: BestmankindBTLUSA Post Number: 6594 Registered: Oct-05 | nice looking amp kevin. good job. good luck in the comp tomorow. |
Silver Member Username: Mygame5982H-TOWN, TEXAS US Post Number: 679 Registered: Jan-06 | thats four gauge? |
Gold Member Username: Basshead86Try Google Post Number: 7824 Registered: Aug-05 | good luck Kevin!![]() |
Gold Member Username: FrkkevinLake Worth, Texas US Post Number: 1409 Registered: Nov-05 | Thats 1/0 gauge... Where the amp goes is a tight fit but it will look clean. After this pain is done I'll have to figure out how to remove my backseats then I'll start a nice new box and clean up the install with panels and such.. |
Gold Member Username: FrkkevinLake Worth, Texas US Post Number: 1410 Registered: Nov-05 | Btw.. heres pics of where the amp is going to be located.. https://www.ecoustics.com/electronics/forum/car-audio/279017.html |
Gold Member Username: FrkkevinLake Worth, Texas US Post Number: 1415 Registered: Nov-05 | welp off to the comp.. hopefully I can get the new amp install while I'm there.. |
