How do u hook up a car cd player into the house?
john j
is it possible to hookup a car cd player into the house the easiest way possible thanks
Anoynymous
Yes!
Get the car as close as you can to your home components and buy long long interconnects.
Username: Illuminator
Post Number: 1573
You need a power supply that puts out 12v DC at 10 amps continuous power.
Username: Project6
Post Number: 3922
Why do you want to do that?
john j
because !
Username: Project6
Post Number: 3929
How compelling!
Good luck.
john j
why do you care why I want to do it?
Just tell me how and begone!
Username: Project6
Post Number: 3937
because !
Jexx already told you how, now begone!
Username: Project6
Post Number: 3938
because !
Other factors come into play, what speakers will you be using, car speakers, are outboard amps involved, etc. Now stop being so nasty, you came in here asking for help as an unregistered guest and you act like a troll.
john j
Geeez,
Jexx said "you need a power supply" then what? how do I do the connections?
Come on, can you guys please be smarter and indicate me how I need to proceed step by step? I don't undertsand, why is that so hard to do?
Post Number: 1581
Step by step will always lead to tedious explanations....something I tend to avoid...
10 amps will run nearly any headunit with all four speakers hooked up to the internal amp.
Yellow+Red wires from headunit need to be hooked up to the Positive terminal on the power supply.
Black wire from headunit goes to negative terminal on power supply.
Speakers are as follows:
Each color represents a pair of wires, one (+) and one (-) for each speaker...
Username: Project6
Post Number: 3952
way to go Jexx!
john j
God bless my brain...I am still confused!
I am starting to worry about it !
Is that picture of a Car CD Player ??
So I get the power supply, connect the left and right front cables to the right speaker and the right and left rear to the left speaker? Will this sound in stereo?
Man, I guest I will just buy a regular home easy to use CDP
Post Number: 1582
Either 1)This thread was in vain to begin with or 2) That isn't Jon J...
