Gold Member Username: My_rantzGold CoastAustralia Post Number: 3087 Registered: Nov-05 | NOT! Looking for the perfect gift (for someone you don't like)? http://www.youtube.com/watch?v=oQdLV6EB5RY |
Platinum Member Username: NuckPost Number: 14800 Registered: Dec-04 | seal the box ends with duct tape, after loosly tucking some tissue paper inside. poke a hole in the bottom rear corner of the enclosure and use the tube of a pen as a port, experiment with port length. Voila! |
Gold Member Username: My_rantzGold CoastAustralia Post Number: 3088 Registered: Nov-05 | Set them up using the WASP method, otherwise you may find them disappointing. If not using the pen port, move them closer to the wall. I wonder if quality stands filled with sand would help. |
Silver Member Username: BoulderdashcciCanton, Massachusetts USA Post Number: 152 Registered: Apr-07 | Think I'm going to sell my Evos to upgrade to these. I've always wanted SDFRs... |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 3770 Registered: May-05 | I'm not sure how much better they'd sound than the Bose cubes. Seriously. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3757 Registered: Feb-07 | Sadly this is just another indication that the "iPod generation" thinks that anything that makes sound is "good enough". For those of you who don't mind scratching the hell out of your vinyl: http://gizmodo.com/5496452/cardboard-record-sleeve-doubles-as-record-player |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 3771 Registered: May-05 | Everything's got its place, David. I honestly don't think anyone is going to think they sound good, or even good enough to replace anything else. They're probably something that someone would buy to use in their cubicle for a few months at best. |
Platinum Member Username: NuckPost Number: 14806 Registered: Dec-04 | Ice fishing hut! When finished, shoot them! |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3761 Registered: Feb-07 | Is that what we do with ice fishing huts here in Canada Nuck? |
