Anonymous | Any suggestions? Room size 10ft X 14ft approx |
Derek | You are going to have to build my friend. You could buy a returned 8" woofer from Mission or Energy or... Wait for this http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=14088186&St=6126&St2=-55154136&St3=54986648&DS_ID=3&Product_ID=9387&DID=7to go on sale. Pick up one of these http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=14088186&St=6126&St2=-55154136&St3=54986648&DS_ID=3&Product_ID=7772&DID=7. Then go to Circuit City and pick up one of those cheap carpetted $35 car sub boxes. You'll need a little bit of wire, some black pan-head screws and a little rubber weatherstripping and maybe a bit of solder but taht should do it - under budget. Good luck and I hope this helps. |
Kar | How about the Velodyne VX10 for $149 from J&R or JBL PB10 from www.bestpriceaudiovideo.com for $169 Havent been able to find reviews for Velodyne on the Net. Reading reviews it seems the JBL would be a bit boomy. |
Kar | Anyone has any views on this. I am also lookin at subwoofers at that range and am totally confused. How is the Velodyne VX10 compared to the JBL PB10 |
