New Membe - Bose system problem....
Username: Kev4heels
Hello everyone. I am new to the boards and had a question about my Bose 321 subwoofer. My system is 6 years old and has a problem with the internal piece of the subwoofer that connects the power cable to the circuit board. My cat chewed through the power cable and shorted it out (sparks/smoke and all!). I bought
a new power cable from Bose, but when I plug it in, there are still sparks occurring at the adapter point still. The adapter(located on the circuit board)has a black mark (power spike) on it. How can I get this replaced? I only need the little
adapter piece (I hope:-)) I attached some pictures of the piece I need to replace. Any help would be greatly appreciated!
Thanks!
Username: Nuck
Post Number: 12520
Time to hit Rat Shack and do a little DIY, ks.
Remote solder the plug to the board and mount the plug in a sturdy location.
Or skip the plug and just cut the power wire and solder direct.
I know my choice.
Depending on the vet bill, I know my choice.
Hope all are well.
Username: Kev4heels
Thanks Nuck! The piece actually popped right off the board, so I think it will go back. My problem - is what is this burned up piece called and where do I order it? Of course, BOSE wants like $200 just to look at it and I don't want to pay that for this little piece.
thanks!
Username: Nuck
Post Number: 12527
I would call it a power cord connector, I suppose.
I have no idea in the world where to order it. Sorry.
Just solder the sucker on there.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 2628
How's the cat?
Username: Dmitchell
Post Number: 2629
Oh yeah, I've heard that you can buy spray at Petsmart that cats hate... you could spray that (carefully) on your cables. Tabasco sauce works too ;-)
Username: Nuck
Post Number: 12546
Or the look of 'recently divorced', that keeps pusssy away
Username: Dmitchell
Post Number: 2630
doh!
Username: Nuck
Post Number: 12549
kevin, is this helping at all?
Username: Kev4heels
Nuck, don't have solder experience, but it wouldnt' matter - the piece that needs to be soldered is burnt and not working. I need to get it replaced first.
I appreciate your help though. If anyone knows how to get this piece replaced, please let me know.
