Help Please, Bose PS18 II subwoofer amp
Username: Azsdh
Hi
I posted this once and couldnt find it so I guess i messed up so here goes again.
I have a Bose AV18 hooked up to a PS18 II sub, while watching a movie all of the speakers just quit, the AV18 is still working just fine, I have another PS18 II so i hooked it up and after 2 days it did the same thing all the speakers just quit, it didnt seem hot , the AV18 still works, I opened up each amp to see if the fuse by the power switch was blown but they are both ok and I also tested the fuse with a fluke meter and it is ok but I turn the amp on and I get nothing. I checked all the speakers including the subs when I unplugged them from the amp and all check out ok just the amp quit. is there a quick fix for this or am I in for a big repair bill since I took out 2 of the these PS18 II sub amps ? :-(
any help would be great.
Thank you in advance
AZSDH
Username: Nuck
Post Number: 11913
Shawn, is this sub the one that comes with the Bose setup?
Bose are very specific.
Username: Azsdh
Nuck
Yes this is the sub that comes with the package 5 cube speakers and the sub with 2 6.5"
