Nad 3020 - noise on power up
Username: Spuddy
I've got a nice Nad 3020a amp which has served me well over may years. recently it has developed a strange trait when turning on the power causing aloud buzzing noise through the speakers. Whilst this is mildly irritating in itself I am more worried about causing some damage to my beloved LS35A speakers. Whats more it seems to be getting worse - anyone got any clues on what could be causing this and how I might fix it?
Username: Nuck
Post Number: 11475
Spud, the power caps are likely very dry and push along a very ugly voltage to the rest of the circuit.
I would not use it until the very nice little unit has been serviced.
Username: Jan_b_vigne
Dallas, TX
Post Number: 13319
Most likely capacitors, either power supply or coupling variety. Take it to a repair shop and don't play it with any speaker you care to have intact until then. Or move on to a newer product with a warranty and better sound.
Username: Soundgame
Richmond Hill Toronto, Ontario Canada
Post Number: 598
Disconnect all sources and see if it does it. Potentially one of your IC could have a bad ground...trust me, it's happened to me.
If that doesn't work, go with the servicing.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 2034
Take it from a guy that has fried some relatively expensive speakers. Have a tech look at it.
Username: Nuck
Post Number: 11486
There are 8 million stories in the neked internet city...
Username: Nuck
Post Number: 11487
Of all the gin joints in all the places in the world, she had to walk into mine...
and blow up my speakers!!!!
Signed Rick
