Gold Member Username: DrsmithMontana USA Post Number: 2683 Registered: Nov-04 | I'm going to buy this monitor http://www.newegg.com/Product/Product.aspx?Item=N82E16824001310&Tpk=2232bw to play my xbox 360 on I'll be connecting it with VGA cables but how do I connect speakers to the monitor? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 13145 Registered: May-04 | . Through an amplifier. |
Gold Member Username: DrsmithMontana USA Post Number: 2685 Registered: Nov-04 | sounds like a pain how much are cheap amps |
Platinum Member Username: NuckPost Number: 11194 Registered: Dec-04 | they are cheap, apparantly. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 13148 Registered: May-04 | . How much are you willing to spend? |
