Step Down Transformers (USA 110V to UK 240V)
Username: Planetzany
London UK
Hi all,
At the risk of sounding a complete clod, I thought I would enlist the help of anyone knowledgeable in these forums in the subject of step down transformers. I was thinking of buying a Marantz 2270 from a USA dealer. I'd be so grateful if anyone here might give me a guideline as to which step up transformer I would need to buy to enable me to use it in the UK? The only other transformer available to buy is the second one below, which doesn't give ampage.
I may also wish to run more than one Marantz receiver. I have no idea of the ampage or wattage though!
_______________________________________
HEAVY DUTY 240V TO 110V CONVERTER FOR LARGER LOADS
STEP DOWN TRANSFORMER
1000 watts, 8.30 Amps
1500 watts 12.5 Amps
2000 watts 16.6 Amps
3000 watts 25 Amps
240V TO 110V CONVERTER 100 TO 300 WATTS
300 watts
500 watts
So grateful for any help anyone can give here.
From a very "novice" novice!
Username: Jan_b_vigne
Dallas, TX
Post Number: 12954
There's a very good chance you will have no warranty if you do this.
Username: Eramsey
South carolina United States
Post Number: 585
Not only will you likely void the warranty but you may destroy the equipment as well. Many makes of electronic gear can be safely converted for use in other countries by the maker or an authorized repair center. I would take this route.
London UK
Thank you very much for this information - I will take heed!
Enjoy your weekend!
Username: Nuck
Post Number: 10758
The UK runs on 50Hz, or is that wrong?
