New member Username: WkwashCo Usa Post Number: 1 Registered: Jul-08 | can someone help me i'm trying to hook up a cable box and a satelite receiver to my denon 3805. |
Platinum Member Username: NuckPost Number: 10587 Registered: Dec-04 | Contact the dealer from whom you purchased the unit for the best customer support. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 12866 Registered: May-04 | . Are you asking for a diagram of how to make the connections? http://www.prillaman.net/ht_info_8-wiring.html Unfortuantely, to go beyond that is almost impossible on a forum such as this when the question is so broad. There are multiple ways to make connections that are correct. It depends on how you want the system to operate. Your owner's manual should provide some assistance and your dealer should be your next location for help. . |
