Additional pre amp hook up support please
Username: Fdiskagain
I have a Carver c-1 premap
what is the best way to hook up the following items.
dbx 400x route selector
dbx 224x noise reduction
Carver c-9 holo generator
pioneer reverb sr-60
technics sh-8066 eq
sound shaper mark 2 eq
Ill be running two tape decks preferrably with one of the eq's for each for seperate taping.
I guess what I am asking is what would be the proper sequence to follow.
Or how do I hook all this up...
I'm new to amp / premap world...
Did I mention step by step...lol
Thanks for you help..
Sorry to take up 1/2 a life time to figure this out.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12763
You're kidding, right?
aaaa...no.
I had them hooked up to my Onkyo tx-ds797
but, this is the first time I have done
seperates.
Have not worked with a amp/preamp system before...sorry..
Here is a wild guess am I close..?
I can hook the route selector to the preamp processor external outputs an input jacks.
I can then run everything from the route selector.
Or:
before connecting the tapes to the preamp I can connect the equalizers then the tape decks without a route selector.
Still leaves me with the issue of not being able to use the noise reduction unit an the reverb.
(sorry about the halo generator...not needed)
thanks again...I'd hate to burn up anything...
Dallas, TX
Post Number: 12764
The fact you now own separates doesn't change how components get connected. The receiver you had been using was simply a tuner/pre amp/power amp on one chassis. So however you had things on the receiver, that should work on the separates.
