| Does any one know the specifications for denon d60 shelf system? I got a used denon d60 without speakers(satellites and superwoofer). |
Hawk | Yes. That is a fine system, and it came packaged with the Mission M71 speakers, which made for an awesome combo. You can get the M71s from any Mission dealer. |
Lewis Mambe | my system (denon d60 personal component system) came with two speakers (usc 60). Now, I want to add a superwoofer since it has a line out for a superwoofer. What subwoofer can I add? Give power, frequency response, size and make. |
Hawk | You should be able to add any subwoofer that is a powered subwoofer, that is, it has its own dedicated amp built in. |
thomson malasha | I have a d60 denon system whose cd player continously spins oncce system is on but does not read discs. I have cleaned lens repeatedly but problem goes on. Also it does not open.What could be the problem and its solution? |
New member Username: EdisonPost Number: 24 Registered: 12-2003 | This is a good sub for a reasonable price: http://www.vertigoonline.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AES &Category_Code=A4 |
