Component Video / Bandwidth
Username: Klaussner
Post Number: 25
Is less than 100mhz a big deal? Anything below the 805 model for Onkyo has 50mhz
Username: Jan_b_vigne
Dallas, TX
Post Number: 12231
The only on paper specs you need to look at are; height, width, depth and weight.
Username: Nickelbut10
Post Number: 1115
huh?
Brian...run your video to your tv.
Run your audio to the receiver.
Don't worry about specs, plug it in, if you have video..u win. Cheers.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 624
Always keep video and audio separate.
Component cables (or HDMI) should run from your set top box (cable or satellite) to your TV, and analogue cables (RCA) to your receiver.
Username: Frank_abela
Berkshire UK
Post Number: 2693
Heh, but HDMI is both audio and video. Furthermore, if you wish to take advantage of the uncompressed tracks of HD-DVD or Bluray, you MUST use the HDMI connection since the audio stream has to be encrypted in transit.
Username: Dmitchell
Post Number: 625
True Frank, but how many people currently have a receiver that is capable of decoding TrueHD and DTS-HD?
