I just bought some new speakers and the cables I was using (Paul Speltz-Anti-Cables) for some reason did not work with these speakers after working prett darn good with my prior set. The cables came with spades on each side and the speakers posts on the back of Cambridge Audio 640a v.1 integrated amp are the cheap-screw-in-all-you-can-put-into-them-is-bare-wire type. The inherent nature of the these crappy posts rendered the Anti-cables useless. These speaker cables are awesome and are the best bang for the buck in cable out there- I just cant use them with the CA.
Any suggestions as to what cables I should get that provide a lot of performance for the dollar? I've been looking at Kimber 4TC's and AQ Bedrock's from Audio Advisor Any advice would be much appreciated.
