How to wire Totem speakers?
Username: Kompressor
B.C. Canada
Post Number: 10
Totem recommends to diagonally wire their speakers, one wire to either top post and one to either bottom post. I read a post here that the metal jumpers that connect the upper and lower posts should be replaced with wire. If so what are the advantages and what type of wire should be used?
Username: Nuck
Post Number: 5149
K, use little jumpers made of your present speaker wire.
Run the out + into the woofer +, then repeat for the -'ses. minuses
You will know the difference right away.
Don't change anything else, speaker position(at all) or listening position, or song.
B.C. Canada
Post Number: 11
Thanks Nuck, now let me see if I understand. Right now I have the + out from the avr to the top + post on the speaker and the - out to the lower - post on the speaker. So all I need to do now is replace the plates with my speaker wire?
Username: Joe_c
Atlanta, GA USA
Post Number: 1221
Yes.
I have mine the same way, I have read that by putting the neg from the amp to the top post (tweeter) first that you will have minute attenuation to the woofer and visa versa but I couldn't hear any difference.
B.C. Canada
Post Number: 12
Joseph, switching them opposit I did notice a little difference and preferred the + on top.
Username: Nuck
Post Number: 5150
Did you find a difference with wire replacing the jumpers?
B.C. Canada
Post Number: 13
Nuck, I have to go buy some wire first I have no Monster cable left over.
Username: Project6
Post Number: 12236
How much wire do you need to jump the gap?
B.C. Canada
Post Number: 14
Berny, you probably need about a foot of wire for two speakers.
Username: Nuck
Post Number: 5151
Kompressor, good time now to measure your speaker leads and shorten one to even the lengths.
If they are even now, cxut a few inches from each.
B.C. Canada
Post Number: 15
I'm thinking of using different wire because the monster cable has very thick insulation around it. What about the ends of the wire, won't they corrode if they don't have connectors?
Username: Nuck
Post Number: 5152
You can spade them later, if you wish.
The leads won't corrode quickly, unless you live in a salt mine.
B.C. Canada
Post Number: 16
Thanks Nuck. I have the Monster QuickLock Gold Flex Pin Connectors for the leads, the spades would work nicely for jumpers.
Username: Nuck
Post Number: 5154
Great!
B.C. Canada
Post Number: 17
Just put the wires in and I would say cleaner highs and maybe a bit better detail. Thanks guy's.
Username: Project6
Post Number: 12239
I was wondering how much wire you need as jumpers for your speakers. It was actually a question I was stating for you. I can't bi-wire my speakers :-)
B.C. Canada
Post Number: 18
Sorry Berny I misunderstood. I found some wire from my old set up, it took about 2.5" for each post. Thanks
Username: Frank_abela
Berkshire UK
Post Number: 1801
In my view, to replace the links you should EITHER:
use the speaker cable you're using currently
OR:
use Totem Tress which is the cable they use inside the speaker. But Tress ain't cheap.
If you stick to one of these you won't be introducing another cable presentation in the chain. That said, I haven't tried using higher quality different wire solutions, and there could be gains made that way.
Regards,
Frank.
