Logitech Z-5500's & Xbox 360
Username: The_kyle
I just joined a few minutes ago and wanted to say hi. But incidently, I have a problem I would appreciate some help with.
Right now I have my xbox hooked up to my 20.1" widescreen cinema display(my 20" tv has a max res of 800x600, yuck) and the audio is going through the cheap built in speakers. I'm wondering if it would be possible to somehow connect it to my Logitech Z-5500's via some type of dual mono/stereo jack to coaxial/optical converter. Or maybe there is something made specifically for this that I just can't find. I'd appreciate any input on this. Thanks!
Username: The_kyle
Nevermind. I just found out my vga cable has an optical output in the base of it. This will be perfect for my speakers!
