Rotel receiver remote question
Username: Twng
Post Number: 9
Hi all,
I just got myself a used Rotel receiver (RSX-1055). The sound is awesome! But I have a problem, as there is no remote came with the receiver. Is there any universal remote that can work with this receiver? Any recommandation? I must say I am on a pretty tight budget, and I spent most of that on the receiver already. Any input is appreciated. Thanks.
TWNG
Username: Jan_b_vigne
Dallas, TX
Post Number: 9460
Put "universal remote" into a search engine and cruise through to find a remote you might like. Get on their web page and they will likely tell you which manufactuers' equipment they can control by punching in a pre-programmed code.
