| My stereo just daunt put out enough power. Dose anyone make a 2 or 4 channel amp something with maybe a gain and blance control and that is it. i will use my stereo as a pre amp so an equalizer will be taken care of. I am looking for at least 20watts rms. per channel. I looked at PA rack mount amps but that are like 600$. |
Derek | Get a Pioneer receiver. 100 watts times 5 can be had for $150 on sale. Sherwood also makes receivers starting at $89. Hope this helps. |
| Are you only looking for 20w or is that a typo? If that is all the power you are looking for and want high current power check out the parasound Zamp http://www.parasound.com/products/specialty/zamp.html Parasound is a premier audio company making some of the best stuff on the market. |
Wacey Hall | I am looking for a cheap 1000 watt or better amplifier. Preferable name brand. I keep burning out the ginaric brands. |
Derek | Here's http://www.hometheaterhifi.com/volume_10_3/buttkicker-bka-1000-amplifier-9-2003.html 1100 watts for $500. |
