NAD 762: Setting up Second Zone
Username: Che422
Post Number: 14
I have the 272 connected to the Pre-Out to drive the two mains. Since I can't seem to do an A/B (the B leading to outdoor speakers)where each is controlled independently, I figured I'd try setting up a second zone. I have a hunch how this works, but would rather know for sure before having to contort myself to get behind the unit and start fiddling. Anyone? Thanks in advance.
Username: Nuck
Post Number: 3316
http://207.228.230.231/manual/NAD-T762-OM-GB.pdf
Username: Che422
Post Number: 15
Nuck...thanks again for the rapid response! Trouble is I'm still not clear on how to set this up. Presently the 272 is plugged into the pre-out to power the mains (from 272's L/R variable ins). Do I run the L/R variable ins to the 762's mutli source out? (If so, I assume I need a Y connector - L/R from 272 to 762 MS out...yes?)
Username: Nuck
Post Number: 3324
Sorry Charlie(could not resist).
If it's not laid out in the manual, I dunno.
Seems simple enough, but no advise from the blind seat here.
Username: Che422
Post Number: 16
The NAD manual isn't always real lucid. I can take a stab but I'm not feeling experimental, particularly since it's such a pain getting back there. If I don't get an authoritative answer here, I'll see if I can get someone from NAD tomorrow. Failing that I guess I'll just resort to trial and error.
Username: Nuck
Post Number: 3326
Youshould be fine, Charles.
Source out to 6&7 in. Tape monitor, maybe.
The machine is built to protect itself from guys like me, so you will be fine! LOL!
Username: Che422
Post Number: 17
Nuck...we're good to go. I misread something re the multi source outs on the 762. It was actually very simple. I'm still a bit disappointed I have to use the 272 for the outdoor speakers rather than to drive the mains, but I'll live with it. Thanks for your help!
Username: Nuck
Post Number: 3330
The main amp for the B speaks?
Swap the speaker leads A+B?
How did that work out?
Username: Che422
Post Number: 18
The 272 for the B's. Haven't swapped the leads -- that's next.
Username: Nuck
Post Number: 3332
righto.
Username: Pepe12
Chicago, Il Usa
does anyone have the knew codes for a pansat 3500sd
Username: Pepe12
Chicago, Il Usa
Username: Pepe12
Chicago, Il Usa
Username: Nuck
Post Number: 3334
knew i dont
