How do i DELETE ALL the SONGS from my iPOD NAN0?!?!
Username: Slikerx3
Nj
please help.. i deleted alll the songs from itunes but idk how to delete them from the ipod itself
Username: R_magee
you can go to settings on the ipod nana and then go to delete all songs
Username: Ftalife
Post Number: 167
remember you will also have to change the settings on itunes to not load those songs again.
Username: Ftalife
Post Number: 168
or you would have to delete them from your itunes also.
Username: Ftalife
Post Number: 169
I would however save the songs and use the feature to select which songs you want to upload to the nano and what you don't want keep off.
Username: Ftalife
Post Number: 170
In truth you could actually change the settings in the ituens first which songs you want and which songs you don't want to load. Then when you hook up your nano to ituens and load them they will be how you like.
