Two Pairs of Speakers using Bi-Wiring Ports?
Username: Jazzy639
Post Number: 7
Hello, I have a Cambridge Audio A5 amp.
I would like to use two sets of speakers temporarily - only for 2 hours. The Amp will be turned up pretty loud.
Is this ok for the Amp? Will the amp be safe and not overheat/fuse/blow up?
Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 8228
Assuming you do not create some sort of weird load with the second set of speakers the amplifier should be OK. If it gets unusually warm, you should lower the volume and possibly disconnect the additional speakers.
Username: Jazzy639
Post Number: 8
Well, the amp gets warm with just one pair at high volume so I was thinkign an extra set would mean i can set the volume lower and thus reduce the amp from heating up?
Thanks
Username: Jazzy639
Post Number: 9
Well ,I ran it with two pairs of speakers. The amp ran hot but its all fine now!
