What's up with my sub
Username: Dglass
I have a Dahlhquist PDQ-1500. It has worked fine the year I have had it so far, but after about the first few months, it has begun to make a popping noise, if I leave it plugged in for a long time. It is supposed to have an automatic shut off when there is no sound current going into it. I don't know what the deal is. Could you all give me a hand and tell me what the problem is and how to fix it, if it can be fixed.
Thanks
Username: Nuck
Parkhill, Ontario Canada
Post Number: 1871
Unplug it when not in use.
In the first few months, it was still within warranty.
Username: Thx_3417
Post Number: 1402
Daniel Glass
What type of films have you played on it since you've had it?
Specifications:
Woofer: 15" Down Firing, 2" Voice Coil, 54 oz Magnet, Crowned Back Plate
Response: Variable from 28 Hz - 150 Hz
Amplifier Power: Class D (Digital) 175 Watts
Peak Amplifier Power: 500 Watts
Amplifier Controls: Variable Volume, Phase, Frequency
Note: the (Baby Boom LFE.1) should be kept at low level, due to the amount of testing that I have conducted on the (Baby Boom LFE.1) alone, I have seen an incredible rise in level on films like "Star Wars Episode 2 Attack of the Clones" which as the heights output that I've seen on any motion picture soundtrack, with lows extending down to 25Hz, with very high dynamic range output.
The way I have my home cinema set-up, is with the master fader at (0db) and with very careful calibration of the separate amplifiers volume, and slight EQ, and rather complex technique that I have used for the sub bass unit, where all the lows from the left centre right and split-surrounds are sent to an audio mixer, this is where I have total control over each output.
The (Baby Boom LFE.1), is also feed into this mixer, and the level as been noted on the VU meter, or meters, and with careful adjustment of the sub bass amplifier, which is driving a JBL professional cinema sub bass (JBL 4645 THX) in the 7 ½ years that I have had it, not a single days gone by with a fault.
Less is more, you should really run the sub bass unit, with less input, or rather match it to "Star Wars Episode 2 Attack of the Clones" with around -3 to -6db less, I think you will still enjoy the films and the music....
Username: Project6
Post Number: 7451
What is the relevance of this to Daniel's inquiry?
Username: Dglass
I have played every Star Wars episode, even the original three episodes. Also, King Kong, Ladder 49, and many others. I am with Berny on this one; what does this have to do with my problem?
I appreciate the help, but could you dumb it down for me?
Thanks,
Dan
Username: Stu_pitt
Irvington, New York USA
Post Number: 1175
Guys,
Andy is a great guy, but his mind tends to wander a little bit. Please don't hold it against him.
Username: I_need_to_know
i have 2 15" spl subs in a box.. but the box has 2 little holes bout the size of a nickle on it... so... whould it hit harder if i made bigger holes????? or what should i do???????????????????????????????
