Pioneer Problems
Username: Rideredder
Cornell, IL USA
Post Number: 253
I have an old Pioneer receiver that I got for free because the guy said it didn't work. He said he took it to two different places and they said that there was absolutely nothing wrong with it. So I plug it in, turn it on, and for about three seconds it seems to work fine until the display starts flashing POWEROFF and then it shuts itself off. I thought I'd start by asking here if anyone knew what the problem was, or have had any problems like this, before I go tearing it apart.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 1632
Open the cover, clean it, and look for cold solder joints.
Check the resistance of the transformer.
'note' If you cant check the transformer, you should not be in there.
Username: Nuck
Post Number: 1645
Make sure that you are using 8ohm speakers.
Username: Nuck
Post Number: 1653
What does it do with no input or outputs connected?
Cornell, IL USA
Post Number: 256
Same thing.
Username: Nuck
Post Number: 1705
Bad news...it's toast.
Good news, you get to go shopping!
Username: Hawk
Highlands Ranch, CO USA
Post Number: 713
How old is this receiver? Also, is it a HT receiver (5.1 channel)? If it is a HT receiver, I suspect it is a software issue that can be solved by a repair depot for Pioneer that can re-flash the memory. Recognize that a HT receiver is a computer and these problems are the result of the operating system getting corrupted.
Cornell, IL USA
Post Number: 258
Yeah, it is a HT receiver with 5.1. I am not sure how old it is. The guy that gave it to me said that he was watching a DVD and it all of a sudden quit working. I only took it because I figured the problem was just a blown fuse or something that I could fix myself.
