50 Watt Integrated Thoughts Anyone???
NAD BEE vs. Creek vs. Jolida 302B
1.Creek-Best all around
2.Jolida-Great Tube bang-for-buck
3.NAD-Great Solid State bang-for-buck
Either one will make a fantastic addition to your household.
Username: Billdashill
Post Number: 79
I'd add the Myryad Z140 to your list also. It uses quality parts more so than the NAD and Creek IMHO.
Noddin0ff
Add Cambridge Audio Azur 540A ($379 list). Good for the smaller budget. Looks much better than the NAD.
Do any of these have a phono input?
Username: Soccer
Post Number: 51
Since I see no prices, for 370$, you can get a good Rotel with loads of current and phono, compared with NAD, the others I don't know them. Should be the more detailed of the lot...
Enjoy
Username: Soccer
Post Number: 58
You can always try to go higher and get a Classé Audio...
Post Number: 82
Yes, The Myryad Z140 has MM and MC phono inputs. You can probably get one for $600-$700 if you tlak them down.
Username: Sun_king
Leeds, West Yorkshire UK
Post Number: 50
The Nad and the Cambridge don't have phono inputs. You'd need to add a small phono preamplifier, Nad and Cambridge both do one!
