Receiver w/ XM Recommendations
Eric S
Starting my search for a receiver. Would like to have built-in XM receiver. I guess I could also get a integrated amp, and separate XM receiver, but I like keeping it simple. Budget is up to $600 roughly, primary use will be music, but will serve double as HT setup someday. I'll probably start with some bookshelf speakers on stands, like Epos M5's, then add a sub possibly.
Username: Edster922
Post Number: 3280
Yamaha rx-v657, you should be able to find it for under $400.
