Bi amping with two Cambridge audios - 640 and 540
Username: Dj88
which should i use for the lower frequency? the 640 or the 540? - the manual says use the more powerful amp for the bass, do you guys agree?
thanks!
Username: Jan_b_vigne
Dallas, TX
Post Number: 6815
I would follow the manual to begin listening for a reference. If you then want to switch the pair of amps to other functions, you'll know what you had according to the manufacturer's recommendations.
craig wallace
need advise on how to run two amps. one alani 800w 4 channel. and one 1100w alani. do i connect amp to amp by bypass rca? or split from head unit and rca sepratly?
