I need some Help with my Ipod
Username: Barisaxmasta
I accidently dropped my ipod in the tolit and then i picked it uot and took it about and dried it. The i pluged it in and it worked but then all of a sudden the screen came up and said there is a missing file. If you know what this means please tell me or if you know how to fix it ty
Username: Project6
Post Number: 4085
There will be problems when you drop any electronic gear in the toilet.
Why do you think that your iPod is indestructible?
No my ipod Still works it just says there is a file missing or something
I Want to have a normal ipod!
Hey, I have a Ipod Mini and, for a long time, it wouldn't transfer songs from itunes to my ipod. I fixed that problem, but, because i tried to update it so many times, when i plug my ipod in, the playlist that says "Matt's Ipod" that shows the songs currently on my ipod says my memory is full, yet i only have 300 songs on it. What can i do? HELP!!!!
My ipod shuffle blinks orange and green and wont play, what does this mean and how do I fix it.
