Anonymous | My system is almost complete. Do I go with the PSB or Atlantic Tech for the rears? Oh, I have to mount it on the back wall BEHIND the seating area, is this a problem? Thanks. Rec: Pioneer 1014 Fr: NHT SB2 Ctr: NHT SC-1 Sub: HSU STF-1 Rear: Help!!!!! |
Silver Member Username: Stealth_cDublin, CA USA Post Number: 247 Registered: Jan-05 | Is there a reason why you dont want NHT for the rears as well? |
Anonymous | Stephen, I had NHT SB1 for the rears and they were great for the DVD-A/SACD, but I watch more movies than listen to SACD. I want a more diffuse and not direct sound (I hope this is the right term). I don't think NHT makes any current small bipole speakers, correct? Thanks. |
Silver Member Username: Stealth_cDublin, CA USA Post Number: 248 Registered: Jan-05 | Well, not to be the Cambridge Soundworks wh0re of the forum, but might I suggest the CSW S300. It gives you the option of direct, dipole, and bipole dispersion. They sound pretty good all things considered and you can pick them up factory refurbished off ebay direct from CSW for something like 200 a pair every so often. |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 428 Registered: May-05 | Send an image of the type surround loudspeakers that you debating over.... Send the picture to my picture and then upload it to the page hear for all to see with some technical specifications, as well.... |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 429 Registered: May-05 | As for the seating problem, there is no seating problem, modify the room with sound in mind firstly, and with that in mind, well think about it... |
Anonymous | Here are the links to PSB and Atlantic. Sorry, I couldn't get the image to upload. Thanks. http://www.atlantictechnology.com/literature/4_5.pdf#search='Atlantic%20Technology%204.5' http://www.psbspeakers.com./s/newAlphaSeries.html |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 433 Registered: May-05 | Well the centre channel is not quite matched to the left and right, drive size frequency response sensitivity are also matched but the size and sensitivity does concern me. As for the sub bass not lower enough down to 20Hz or just bit lower 18Hz, would suffice. The point of the screen channels is that, in a top sounding THX cinema bass can be big on its dynamics in the centre channel most times, I Kidd you not, dual 6 ½ or 8 inc ones, but if you are patent enough why not one15inc with a loaded horn compression driver that will be the choice. The Atlantictechnology looked ok, then I saw the psb range and said maybe, as for a demonstration at home bearing in mind use a SPL meter when testing these out, for tight bass line response detailed mid range and high frequency with sparkle and transparency too. As I a have gut instinct they would not do well on "Indiana Jones and the last crusade" in full six-track Dolby stereo, on DVD and if you haven't seen the film in 70mm Dolby THX then you may be lost, sorry about that it's the projectionist in me come out there, try a home demonstration for the week end. Oh as for the L.F.E on these subs it will be blow to hell, and if you AVR doesn't have THX with its Peak THX manager audio limiter, then buy an of the self audio limiter form a PA sales shop not a Hi-Fi shop as they wont have any in there show room, but they may be able to order you one. |
Gold Member Username: Paul_ohstbucksPost Number: 1436 Registered: Jan-05 | The rears arent critical to the system because they dont carry a heavy load, and typically only sound effects play through them(bullets, footsteps, crashes, etc, etc). I wouldnt overly sweat the decision. Just about anything will work just fine. Heck, I use cheap Bose161s in the back for the only reason that their shape and wallmount perfectly fit my necessary application, and they serve their purpose just fine. Buy whatever fits your physical needs, and dont spend too much on backs because they play a 'back-seat' role to the fronts, center, and yes...even the surrounds. Pun intended. |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 439 Registered: May-05 | Paul What are you trying to do get this guy to buy small surround loudspeakers, and blow the hell out of them, mate look at the technical specifications on Dolby and dts digital 20Hz to 20 KHz left centre right and split-stereo surrounds, with L.F.E 20Hz to 120Hz. Anonymous, unless you don't what the surrounds bottoming out on the low frequencies, bigger around 6 ½ diver size with a very good passive X-over, although active electronic X-over units are the preferred choice that's of course you have plenty of bread, for a B-chain set-up... |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 113 Registered: May-05 | I don't know if you're on drugs, or need to be on drugs Andy |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 440 Registered: May-05 | Oh to add to this just play "Earthquake" Sensurround now on DVD in full six-track Dolby digital, on the surrounds only just play the surrounds, turn of all the other channels including the sub bass and see, how much low end you can feel coming of the split-stereo surrounds, you should have peaks of around 105dbC weighting climbing to 110dbC weighting if you lucky enough to see it on the SPL meter. |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 441 Registered: May-05 | Hallo there Stu Pitt Quote "I don't know if you're on drugs, or need to be on drugs Andy" No, are you and what is your profession as a former cinema projectionist for UCI and Warner village cinemas UK, I feel that Anonymous, should know a few things. What AVR are you running in your home cinema and loudspeakers included. |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 115 Registered: May-05 | My point exactly... What are you saying? Are you asking me what my profession is? Being a former cinema projectionist doesn't make you an expert in home theater. It just makes everyone here laugh that much more at you. I bartended at a brew pub while in college. Does that make me an expert in brewing beer? No... My job wasn't to brew beer, just like your job wasn't to set up speakers. |
Gold Member Username: Paul_ohstbucksPost Number: 1443 Registered: Jan-05 | Hahahahahahaahh when I was in college, I worked at a gas dock fueling boats. I guess that makes me a fuel expert?? |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 116 Registered: May-05 | Paul - Way off... According to our special friend, that makes you a Captain. |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 117 Registered: May-05 | Now that I think about it, in high school I worked at a car wash. That makes me an expert race car driver. |
Gold Member Username: Paul_ohstbucksPost Number: 1444 Registered: Jan-05 | Ahh yes, I am a Sea Captain, and master of the sea!!! |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 118 Registered: May-05 | Seriously, is this guy mentally challenged? If he is, I apologize. |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 445 Registered: May-05 | Well hell that must make me an admiral then. hahahahaha |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 446 Registered: May-05 | Stu, Just say thank you nice to have you onboard are little boat, and I'm proud to have been a projectionist. The Dolby CP processors like the CP-65 and 500 nice pieces of audio processing, although I didn't DTS-6D that much, how ever there newer range like the DTS-6AD does look the part its up there with the Dolby CP-200 and CP-650 as well. |
Anonymous | Didn't mean to get everybody worked up. I just wanted some surrounds without breaking the bank. I understand that my current setup might not be the best match, but I'm happy with it. If you had to choose one of the 2, which one would you choose? That is all I'm asking. Thanks everybody. |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 119 Registered: May-05 | Sorry anon, we tend to get a little side tracked now and then... I'd say the cheaper of the two because the surrounds don't really do that much in home theater. If you are listening to a lot of multi channel music, then I would try to listen to them both and determine which is better myself. I really don't know much about the atlantics, but I own PSB towers and can't recommend then enough. If you are going for multi channel music, I'd say get a pair of matching NHT's |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 120 Registered: May-05 | "The Dolby CP processors like the CP-65 and 500 nice pieces of audio processing, although I didn't DTS-6D that much, how ever there newer range like the DTS-6AD does look the part its up there with the Dolby CP-200 and CP-650 as well." Where the hell did this come from? You know Andy, just when I think you can't possibly get any dumber, you turn around and do something like this... AND TOTALLY REDEEM YOURSELF!!!!!!!!!!!! |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 121 Registered: May-05 | I couldn't help it. |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 448 Registered: May-05 | No didn't think so, so does New York have any THX cinemas around with the noisy underground trains, still to this date? |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 123 Registered: May-05 | Probably... Are you still watching a 20 inch black & white tv with a JBL home theater in a box speaker set, and a $100 Kenwood receiver? |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 452 Registered: May-05 | That's right, will it still blows me away from the first day every day without, shelling out money, money all the time like you guys do or should I say amateur, so don't be a big head ok. Just learn a few things or two and stop thinking the home cinema products are all out to be what you think they are made for, is that why you upgrade every 1 to 2 years hell I haven't done an audio upgrade in 6 years, just adding on, seeing I don't use the internal amplification, adding on active X-over units even Dolby NR 363 SR/A is a neat touch. ![]() |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 126 Registered: May-05 | Andy - Hallo There!!! You know what JBL stands for? Junk But Loud! Anyway, I didn't realize you were a professional sound tech for the theaters you used to work for. I thought you were a projectionist. My fault. I used to bar tend at a brew pub while in college. I'm going to find a brewing message board and lecture everyone there about how I am a former bartender and know more than they could ever know. |
Gold Member Username: Paul_ohstbucksPost Number: 1454 Registered: Jan-05 | I wouldnt necessarily say that about JBL. They have a significant presence High End market too. I'd be interested in hearing their K2 and TIK speaker lines. I probably could 'settle' for owning a pair of these........ http://www.jbl.com/home/products/product_detail.asp?ProdId=K2%2ES9800WG&SerId=K2 &sCatId= |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 129 Registered: May-05 | You've got a point Paul, but Junk But Loud! does describe 95% of their stuff. I'm not a JBL basher, per se. I bought my father a pair of their small towers when I was in high school. They sounded great with his old Marantz 220B receiver. This was before the Harmon Group took them over and destroyed their affordable speakers. Their speakers used to be very good and cheap, a combination that all of us can appreciate. Then the Harmon group bought them out, jacked up the prices, and cut costs of manufacturing by making them as cheap as possible. This is why they are only sold in places like best buy today. A lot of hi-fi shops used to carry them. Now none of them do. |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 130 Registered: May-05 | Andy - Hallo There!!! I really don't have a big head at all. Everything in my system was bought at a discount. My Nad integrated amp cost me $350, NAD CDP cost me $250, PSB Image t55 towers cost me $550. $30 interconnects and $20 speaker wire. $1200 total. I could have spent far more for the same system, or spent far more and gotten worse. If spending $1200 on a stereo system that will blow away just about anything else dollar for dollar gives me a big head, then I'm proud to have a huge head. |
