Center speaker question (problem)
Odiar
I just bought a set of Klipsch synergy f-1 floorstanding speakers and a matching center channel. My tv sits on a stand that has 2 shelves under it. I have to put my reciever, dvd, and cable box on the top shelf -- leaving the bottom shelf for my center speaker. I know I could set up a shelf on the wall above the tv, but...
Is this a problem, having the center speaker that low to the ground? What if I could aim it upward?
thanks.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 752
Try it!
Seriously, why not just try it on the TV for one evening and then on the bottom shelf. You'll have a reference to know the difference.
