New member Username: OnyxwulfPost Number: 1 Registered: May-05 | Recently purchased the following: 2 B&W 602 S3 fronts 1 B&W LCR600 center 2 B&W MT1 rears Rotel RSX-1056 Reviever Rotal DVD player I am looking for a good woofer that is around $500 for this system? Am I okay with the B&W ASW600? OR the ASW650? Or something else entirely? |
Silver Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 532 Registered: Feb-04 | You're posting in the wrong forum. This is for car subs... Kidding! There's no need to timbre-match a sub to other speakers so there's no need to stay in the same brand. This is for home theater and music? For $500, go with SVS or Hsu (or just Hsu if you're in Canada). You'll get much better value. |
New member Username: OnyxwulfPost Number: 3 Registered: May-05 | This is 95/5 movies/music. SVS huh? I will look into that thank you. |
New member Username: OnyxwulfPost Number: 4 Registered: May-05 | http://www.svsubwoofers.com/subs_pci_25-31.htm That one sounds pretty good for what I would be looking for? |
Silver Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 536 Registered: Feb-04 | Absolutely, but for $50 more, you can get: http://www.svsubwoofers.com/subs_pb12_isd_v.htm which you can tune to even lower frequencies. Arthur just ordered one today; check out his thread on the "speakers" forum. Having said that, I own a Hsu STF-3 (also goes to 25 Hz, and I tend to think that's plenty low) and I'm very satisfied too. I posted a note about that too in that thread. |
