Sobwoofer or not?
Neeraj
Dear Sir
I have a MHC-GN77d in a small sized room withoput subwoofer. I use it to listen to cds and cassettes and view 2 dvds per month. would you recommend a subwoofer with it? will the subwoofer work with cds and/or cassettes? The recommended Sony SA-GN1 subwoofer is not available in Delhi, INDIA. In fact no seperate subwoofer from Sony is available. Can I use any other subwoofer of a good brand?
Thanks
Best regards
Neeraj
Username: Edison
Glendale, CA US
Post Number: 642
You can add any powered sub to it - any sony sub will do, like sa-wm250.
njain
thanx
Does it has to be active? what size would you recommend?
Username: Edison
Glendale, CA US
Post Number: 648
An active one will sound better, so i would definitely get an active one.
A bigger one sounds better, but I wouldn't put a lot of money into a your present system. A small sub will be ok - my rational is if you are looking for a better sound, I would go with a separate system - separate receiver, cd, speakers.
If you just want to add some warmth to your present system, go with a sony sub - the bigger tha better actually, but they cost more naturally.
Even the sa-wm 250 is not bad - sony subs are a great value ! Even when you upgrade your audio, I would keep the sub.
