Like
Help stereo receiver
Username: Lorand
can you recommend me a good, neutral sounding stereo receiver?
I intend to buy Denon DRA455R Have you any experience with this receiver?
Thanks for all kind of advice, suggestion
Username: Artk
Albany, Oregon USA
Post Number: 274
What's your budget? Marantz SR4320 retails for 429.00 and trumps the Denon hands down. Rotel makes the RX-1052 which is outstanding at 899.00, and NAD has the C720BEE which goes for 599.00. These are the best stereo receivers that I know of at under 1k. Go forth and listen.
Username: Edster922
Post Number: 193
Also look at the H/K 3490, that'd be my first choice probably. About $300 shipped from jandr.com
Username: Touche6784
Post Number: 268
he meant 3480
Username: Edster922
Post Number: 194
whoops, right you are Christopher! Time for bed I think. : D
Facebook
Shop Related Deals
Directory
