If I were in your shoes, I'd personally remove the damaged speaker from the cabinet, and take it to an authorized Sony Repair contractor, and either have them fix it, or order a new one.
Thanks Paul... I brought it into the repair contractor and they said pretty much to buy new speakers. Any thoughts about replacing the one damanges woofer w/ a similar one?
A repair contractor told you to buy new?? That's weird since they make their living off rebuilding speakers.........
Any repair contractor should be able to rebuild the speaker to be like-new. At the very least, they can order or put you in touch with someone who can arrange an adequate replacement.
Absolutely, you should be able to either rebuild, or find a replacement.
