freemanzhu Unregistered guest | I'm looking to spend $1000 to $2000 on a pair of floorstanding speakers. I listen almost exclusively to classical music, so I put a premium on neutrality and good imaging. Bass performance is important, but less so than the other two criteria. It looked like the PSB Stratus Silver i received very favorable reviews and offer what I'm looking for in speakers, but they are being discontinued. Anyone have other suggestions? |
dd Unregistered guest | I have a set of Vandersteens and think they are a terrific value and in your price range. Check out www.vandersteen.com |
Silver Member Username: Elitefan1Post Number: 239 Registered: 12-2003 | Monitor Audio Silver 6 or 8. With a warm receiever or amp are wonderful for classical. |
Bronze Member Username: JonmoonPost Number: 74 Registered: 12-2003 | Let me make a couple of different suggestions: Look at Martin Logan (Mosaic or Scenario). Here are a couple of threads: www.martinloganowners.com/forum/messages/3551.html www.martinloganowners.com/forum/messages/3642.html And a review of the Scenarios: www.audiorevolution.com/equip/scenario/ Look at Phase Technology. Here is a thread: www.avsforum.com/avs-vb/showthread.php?s=386778476897fe1e9daed5b5b3bfabca&thread id=353531&highlight=phase+tech Look at Magnepan: www.avsforum.com/avs-vb/showthread.php?s=386778476897fe1e9daed5b5b3bfabca&thread id=365455&highlight=Magnepan There are lots of speakers with different sounds. I bought the Martin Logan Montage because of the price and it blew me away for the price point. Good luck. |
Bronze Member Username: ScoobsPost Number: 13 Registered: 01-2004 | i'd give the polk LSi15's a serious listen. i have them on order when my house is finished being built in may. they retail for about $1700 for the pair. if you like a neutral sound for acoustical (classical) music, these might be a exceptional choice. the base isn't boomy, but very tight. here is an excellent review of the speakers by Wes Philips of OnHiFi (plus they were the "OnHiFi's" co-product of the year in 2002 - link provided as well). http://www.onhifi.com/product/polk_lsi15.htm http://onhifi.com/product/2002_productsoftheyear.htm |
