Fisher MT-6117 belt replacement instructions?
Username: Mbfav
I have a Fisher MT-6117 turntable that wasn't playing at a consistent speed so I thought that the stylus might be the problem. Ordered one...that didnt fix the problem. Then I thought, maybe the belt...so I ordered one. Now while I wait, I took the platter off and have NO earthly idea how to get the belt back on (the existing one or the new one when it arrives).
The platter has a cog that seems to fit into a larger wheel in the center on the table. Both have notches that indicate they fit into each other. Also, there is a pulley that rotates supplying the speed. Other than that, I have no idea what the belt path is supposed to be. Any help would be greatly appreciated. Thanks.
